After an accident, i am replacing the frame of my 87 GN with a frame from an 83 Cutlass. I am nearly ready to set the body back on the frame, but the drive shaft appears to be one-fourth to one-half inch too long.
Even when forcing the driveshaft fully into the transmission, the rear u joint will not go into the yoke on the differential. Since the body is not on the frame, the rear shock are fully extended.
Any thoughts on what may have caused this, or a possible remedy other than shortening the drive shaft?
