Zacks 85GN
Zman
- May 24, 2001
Finally getting the motor together and installed the cam and front cover. Tried to install the cam sensor and it will not seat all the way down, app. 3/16". We have turned the motor over to engage the oil pump shaft and it will drop down like it has engged the oil pump but will not go that last 3/16". The cam sensor is turning when I turn the engine over. What I have is a ATR 309G roller cam, a new HV front cover from MMC (about 4 or 5 years ago), and a stock 85 cam sensor. Any Ideas? There were no instructions with the cam kit, hope I got the gear and spacer on right, only looked like one way it could go on. Search did not turn up much.
