0 03FatBoy Member Joined Nov 10, 2008 Oct 10, 2009 #21 Also interested in the correct upper plate spacers... all I can find is the flat ones.
W Wknight13 Member Joined Dec 14, 2001 Aug 28, 2019 #22 21 posts and still no mention of actual underside screw size to put bracket on. Sent from my SM-G930P using Tapatalk
1KWIKSIX Well-Known Member Joined Sep 29, 2007 Aug 28, 2019 #23 G Body Parts sells these upper round white plastic licence plate mounting tab / spacers. Cheap at $2.95 each GBodyParts.com Online
Hotfoot Active Member Joined Jan 1, 2016 Aug 28, 2019 #24 6x1x20mm long when I got mine off of an 85 regal it had 2 spring nuts and bolts. on my Gn the aluminum bumper support was threaded 6x1 so I did not have to use the nuts Attachments CA649B79-754B-462B-86BC-3FCADE65238F.jpeg 3.9 MB · Views: 10
