FS: HKS T45S Turbo (800HP)
turbogray
Selling a used working HKS T45S turbo (journal bearing) along with a 4 bolt flange to mate to the turbine exit. Has very small nicks on the compressor wheel, but it has not affected the turbo, as there is no shaft play.
.90 A/R T4 divided HKS hotside housing. Maximum power should be around 700whp. I believe this to have about a 67-70mm compressor.
Background on the turbo:
This is an old school Garrett unit (HKS used it until around 1998), made in Japan, and is essentially a TA45 with an HKS turbine housing, so if down the line a rebuild is necessary it should not be difficult. Although it's rather old tech aero-wise, it has high quality internal components, is built like a tank with a large frame, and should put out reliable power, asking price is $400.00 OBO.
thank you
