I just installed a walbro 340 pump and hot wire kit today. Every thing went fine and started up fine. The reason I changed was because I only had 28lbs of fuel pressure with the hose on and about 30 with it off. Now after changing the pump I have 32lbs with hose on and 38 with it off. Is this normal pressure or is it too low? I thought it was supposed to be around 40-45 lbs. I tried a search but didnt come up with an answer. What else should i check? It also pops out of the throttle body when reving the engine, which I thought was due to low fule pressure???
