fuel pump for a lt-70
N2HIPSI
1 of 463
I just purchased a Lt-70 turbo. I had a t63-e before. I still have a hot-wired 340 and 75# injectors. I was able to run 24lbs of boost with the 63 and had no delivery issues. What fuel pump setup are you all running with this size turbo and am I pushing it with the single pump? Thanks
my .2 cents
I would say yae,you should think hard about getting a double pumper.Do you have volt booster,I am running a double pumper. better to be safe then sorry If you want to run in the mid to low 10's.Also are your Injectors Low z's?And just how fast do you plan on running?
I'm loking for mid 10's. I was'nt really looking for the turbo I bought but, I kinda stole it( price wise). You can see by my sig that my setup is close to yours. I figured I'd be looking at a double-pumper. Thanks
Call red a Quad Air he can Really answer all the tech questions you may have and also help you get the right pump set up.That is what I'm running now...Good luck
