go with the 340...why go through all that work to put a small pump in? it will work for now but once you upgrade, and you know you will, you will need to do it again. Id go with the 340 and leave it at that! not a problem with a pump that might be alittle big, but too small is def. a problem. Hope this helps,
Jamin
