fuell cell or in-tank for turbo LS E85 GN swap
chub406
Hey Guys,
Im starting my 6.0l turbo e85 GN build. I was going to put a cell in the car but I really like the idea of an in-tank pump. Load fuel pumps get annoying. I know to get the GN gas tank or 4.3 monte. Will the tank let it certify to 9.5's? Pros or cons to the two? I s it easy to find an in-tank that will be big enough? What are you guys using?
Hey Guys,
I have a fuel cell and Weldon pump in the trunk
To pass tech I had to install a rear firewall
I can no longer here the pump over my exhaust tone after the rear firewall install
-Dan
What are you running for exhaust? Even when you are just cruising around? What all did you have to do for the firewall? Mine would be outside the car.
