malibudave
- Apr 14, 2004
Attached are some installation pictures from manualbrakes.com
To run this setup, it is best to use a vacuum assisted brake pedal since it already has the hole for the new pin location for the manual brakes.
Using the vacuum boosted pedal will give you a higher pedal ratio for more leverage and less effort to stop the car.
