what is the difference in cork and rubber gaskets? does one provide more horsepower? i have seen many fel-pro and such gaskets come in cork so is this better? please help me!!!!
Im going to answer anyways. The differnce is the material .....hmmmm lets see one is rubber and the other one is cork....will it give you more HP??? NO
I would like to know which is better, cork or rubber? I'm on my third rubber pan gasket, was told they are the best, and it still leaks. Going to try cork next time.
19yearboost, don't take it personally. Some of these guys act like they came out of the womb with all the knowledge of the universe, forget they were new at one time as well.
If you are on your 3rd gasket then something is wrong. Make sure that your surfaces are clean and dry when assembled. Both are good. I prefer rubber. Are you torqueing to specs? too tight is bad also.
