Column ratting (formerly Make It Stop)
So what is the noise in the dash that sounds like plate rattling on a tile counter? I have looked and looked and can't figure it out. It's there only when you move ( I think because it's the only time if gets moved).
Any time you are moving it rattles. It's worse when you hit a bump. It's not the mind-warping squeak of the hood center support. It's in the area of the cluster. I thought it might be related to the speedo cable (I was grasping at straws). It's not the cable. There is no straw in there either.
Anyone know what it might be?
