I have six of these, NOS wiring channel - very rare. This is the part that wraps around the drivers side valve cover, behind the engine and bolts on under the coil pack. Long gone from GM, this would be used to restore your engine harness and underhood appearance. The lower part under the channel (filler) is not available, so you must re-use the original one. Also the little plastic rivets that hold the two pieces together are not available as far as I know, but I have seen them at Autozone. Small black cable ties work well.
$55 shipped, paypal only.
![channel_GN_wire_harness.jpg](/proxy.php?image=http%3A%2F%2Fwww.gndash.com%2Fjohn%2Fchannel_GN_wire_harness.jpg&hash=790ca66bad2b6f3b7d75b1ced6416abc)
