hooker 2.5" exhaust needs new mufflers asking 150 OBO
im not 100% on the mileage but im pretty sure its around 95 before it was apart
ARP main and rod bolts (under 200 miles)
fresh king main and rod bearings (same as arp hardware)
the crank is std/std
new lifters
stock rods/pistons
stock heads/cam
Rjc powerplate
ported upper plenum
mallory adj fuel pressure reg (under 300 miles)
the headers have been milled and welded so they are pretty damn good
50lb injectors
mini starter
percison turbo turbo saver/ filter relocation kit
this does not come with a turbo
asking 1600 for the above OBO
i will personally deliver the motor within a 3 hour radius of detroit michigan
6776e precision turbo forsale it was rebuilt from precision last year saw 5track passes and 3 street races the car had a precision turbo saver and tial 50mm blow off vavle this turbo is mint
asking 700 OBO
turbotweak chip for 50s 90$ obo (comes in a ecm)
pm is key guys
thanks
new lifters
stock rods/pistons
stock heads/cam
Rjc powerplate
ported upper plenum
50lb injectors
mini starter
asking 700 OBO
pm is key guys
thanks
