Overall, engine runs OK, but when you first press the acelerator (hot or cold)it seems as though it isn't getting gas, therefore stumbles, then revs up as normal. Also misses a little while driving but not all the time, sometimes seems like its gonna cut off.
The ignition module tested OK, coil voltage checked out. New wires which ohmed out great, new plugs. Fuel pressure steady at 40psi.
TPS? Ideas anyone?
TPS? Ideas anyone?
