- Sep 24, 2010
Thats already a nice engine!
Interesting boom on that engine hoist? Never saw one slide on from the outside.
I have the same thing, just made some removable extended outrigger bars with wheels for the bottom. Works great!
Thanks everyone.
Having a head gasket debate with myself now. I bought cometics to go with the champion ported iron heads but I have a stock block which is not being touched yet.
I'm told that sometimes the cometics will leak and seep because the stock block doesn't have the surface smoothness that the heads have. Not ready to machine the block at this time.
I'm now also hearing that a head gasket like the factory felpro would be a better fuse than the cometics and might be a safer way to go...
Any advice?
23-25# every day. 27-30# for the few track passes I might make in a year.How much boost you going to have ?
Ok. Provided I crept up on that boost number while avoiding knock with 3 or 4 passes once per year, I thought I could get there safely but I see what you are saying now about it physically holding up.30#lbs of boost ? On a real street car?
I went 10.30's all day long on my old build at 23lbs MAX. A very thought out built, soundly, carefully built 109 done by Lou Czarnota.
If you don't machine and fortify the block, as seems to be your intension, with clearance machining, forged internals and billet caps, you're askiing for a disaster.
But then again, I could be wrong.
I don't want you to have to spend money twice........
Work billet 6262.What turbo are you using?
Work? From Reed?Work billet 6262.
Yes from Reed.Work? From Reed?
IMO, if it's the stock bottom end I'd stay away from anything over 24-25 and even that I think is pushin it.
Are you switching over to E85? If it's available in your area, then I would. Good luck.
My thought is if you are going to go over 23 pounds at all, have the Cosmetics installed.
