Getsidewayz04
- Aug 23, 2006
okay so today i started pullin things off the car in prep for goodies on the way. Im gonna install the RJC plate, new valve cover gaskets (leaking), 100# springs, injectors, n a few other little ends. I noticed while taking off the ignition mudule that there is a large spacer between the intake manifold and the dog house, its at least a 1/2" thick and is dark in color. Is this a stock part or is this something aftermarket the previous owner may have installed?
also i removed my intake tube, up pipe, and the turbo inlet bell. i want to port the turbo and wanted to know how hard it is to remove the compressor side of the turbo? i dont want to damage anything and I know how careful you have to be with the turbine blades. Stock the turbo bell that bolts on is already larger in diameter than the turbo inlet itself.
And lastly I removed the accordian style junk tube that connects to the turbo and there was a massive leak right at the inlet bell. Part of the tube was not correctly fit over the inlet bell and there was a noticable gap where air obviously was entering. since this was unmetered air entering the intake how much of a hindrance could this have been on performance?? sorry for all the questions but you guys are always such a great help!!
thanks again,
Nick
thanks again,
Nick
