Harness
v6turboman
Tying to remove the harness from where it plugs into the firewall just below the wiper motor. Can't quite figure out
how it comes apart, any help would be greatly appreciated.
The engine side, right? There's a bolt in the center with a 1/4 in. head. After it's backed out the connector can be pulled out, but mine had some type of sealant sprayed on it which made it hard to do. Lemme go get a pic, brb.
The wires on the right are for the front lighting/horn harness. That connector will seperate from the rest of the of the assembly when removed from the fuseblock.
Thanks a bunch, I missed the bolt in the center, it to must be covered. I think this would explains my difficulty
