I will agree a line lock won't cover up for bad brakes, drums probably can't hold the power/torque like a disc can.
Actually, drums can hold far more than discs can. That's been proven time and time again.
Where discs really shine is not in their clamping force, but rather in the ability shed heat, very fast. Not nearly as prone to fading as drums.
Now, that being said, the reason a lot of guys think drums can't hold is for the heat reason alone. Get a drum even warm, let alone HOT, and it looses almost all of it's "clamping" power.
That's why a line lock is SO VERY IMPORTANT, if like me, you're a "foot brake launcher".
It's imparative you do a burnout without stressing the rear shoes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That heat just doing a burnout by footbraking in the water will virtually kill their ability to hold boost on the line.
With a car like mine, doing a burnout without the line lock to hold the car in the water, I can usually hold maybe 3-5# of boost on the line.
Doing a burnout with the linelock to keep the rear shoes cold, It's pretty easy to hold 15# of boost on the line.
BTW, I should add. Line locks go on the FRONT wheels, not the rears.
