The best suggestion I can give you is .. let someone that has VAST experience set your heads up... what I mean by this is ... sure the valves and bowls will get you power.. but there is just as much power to be had in OTHER areas that you can address that only a experienced guys will know.. and most won't share the information .. its worth the money
difference ... bolt on 20 hp compared to "BRAND X" ported heads
