header panel
ssleeper94
will it run?
I'm in the process of redoing my buick putting all my 87 parts back on my 82 body. Im in the process of stripping the header pannel for paint, do i have to strip the entire thing to bare fiberglass or just smooth
Bare! Take a (straight)paint stick and sand top.flat in "x" 's to block and straighten the fiberglass, all headers are wavy but if you block it in a x fashion, it will be arrow straight. I used 150 paper and worked down to 220, put 3 coats of fill type primer on,let bake in sun for a day,re-blocked it with 220 paper,finished up with 400 grit,applied 2 more coats of fill primer , final sand 400-500 for base-coat.....
