TireFryer
The New Kid
- Dec 21, 2001
So I pulled out the headlight/parking light switch to test in another car. Then I put it back in and try to start the car. But when the key reaches the "run" position the headlights and running lights turn on and the switch is off... Tried a bad switch and the same thing happened. If I took the switch out they wouldn't turn on. The car does start and the turn signals and everything work, I just can't turn the lights off without pulling the switch or disconnecting the battery. Thanks in advance!!
