Silver Fox
- Apr 17, 2003
I just bought a Hellwig pro-touring bar and started to install it tonite. I have a TA Performance rear end cover, which is a lot thicker than the stamped steel factory cover. When positioning the sway bar, I am getting some interference with the cover and have to position the bar fairly low. I was just wondering how the positioning of the bar looks compared to everyone else's. I will call Hellwig tomorrow and get their thoughts. Here are a few pictures.
A few different pictures. Car is one the ground.
The front of the bar is angles up pretty good. Pretty much the same angle as the rear control arm is at.
I am just wondering if the center portion of the sway bar should be a little higher up on the cover (and the front of the bar would be more parallel to the ground)? If so, I can always replace the cover with a chrome one I have.
Thoughts or pictures of installed ones?
Thanks.
Rob
Thanks.
Rob
