Kid Turbine
- Jul 17, 2007
Okay here is my problem, I have a low end stubble around 2300-2400!!
Crank car in the morning warm it up, I can drive the car for a couple of miles but when I have to crank the car again. I would have to flip my underhood fuel pump switch that I use to adjust my fuel pressure with to start car then turn it off.
But from a dead start into a roll then give it gas it breaks ups then let off car shifts then its fine
But from a spool up start the cars starts to spool but begins to break up then but jumps into boost
Car is limited to 10lbs of boost on watsegate
Is the fuel pump the problem?
Turbo Tweak chip
New plugs with 43lbs fuel pressure
Have MSD DIS4 with coil interface
turbo 350 with Transgo modulator kit
but my mods is in my sig also
Help me cause its getting to the point of pulling setup and installing my lq9 6.0!!!
Turbo Tweak chip
