Current setup
3" DP, P&P Heads with bigger valves, 208/208 cam, 2800 stall 12", Newly installed turbotweak chip, 60's and GN1 FMIC. I attached my turbolink file for review. (Yes I know the old way). Trying to move my car to the latest chip tech. The chip is amazing at idle. The issues I had below were way worse with the old KB chip. But I want to eliminate the Knock before I push things any harder.
ISSUES: As I slowly start to get on it I get Knock at only 12lbs so I let off. I did another run that I forgot to record where I launched hard out of the hole. No knock until 2nd once it gets to third I can see the knock detector light up so I let off. One strange thing that I have not figured out is that each time when go from park to D or R the knock detector goes off. ?????? you can see it in the data in that I have 2 ESC count at the beginning of the file. IAC reading are wacky after the chip change as well. Battery was just replaced so that should have rest it ? Y OR N. O2 sensor is new and values look good when i start to get on it. Last thing is when I let off there is a loud almost like a sneeze valve sound or sudden air flow change. Not sure if this the better air flow from the FMIC or what?
Any help would be appriciated
