I just got the vehicle yesterday and according to the previous owner, he believes the timing chain was replaced about 40,000 miles ago or so. He told me the vehicle has been doing that recently and attributes that to the vehicle sitting in the garage a lot instead of being driven. The GN started right up off the trailer and I drove 25 minutes and turned it off for about 10-15 minutes and started up and drove back 25 minutes w/o any issues. The car sat for about 30-40 minutes and then wouldn't start. It cranks fine and sounds like it wants to start and a few times it did for a few seconds but immediately stalled. The previous owner said I promise it will start if you jump it or use a jump box and then let it run for a little bit until the volts get up. I jumped it for 10-15 minutes and it did start and drove it for another 10 minutes with no drive ability issues. There is a scan master inside and the volts fluctuated between as high as 13.9 to as low as 13.2 while idling. The battery is Interstate and is supposedly not very old. I thought the same thing as stated above, cranks but no start has to be fuel or spark related but supposedly the fuel pump is relatively new also. Thank you everyone for your help, I'm wondering now if I should just try to sell the car??
