Trans. rebuilt early this year because I had no reverse when backing up. After
idling for approx. 1 min. finally I felt reverse gear engage and drove to work. Car went directly to the trans. shop and after transmission teardown, they found nothing wrong and proceed with trans. rebuild using Kevlar clutches. When I got the car back, it shifts very hard in reverse only. Recently, for 3 days straight, drove to work, parked my car at 8 am, by 6 pm I move forward and then shift into reverse to backup, no reverse were felt as if in neutral, gave some gas it made a clucking noise as if trying to engage with slight movement and slipping were felt. After iidling for approx. 1 min., reverse finally engages. Right now it is back in the trans. shop. Any ideas or suggestions?
Thanks in advance.
Thanks in advance.
