help...vacuum line confusion.
street6
pushing stock limits
In the process of doing an engine swap. I'm removing my stock 55k mile motor and installing a warmed over roller motor. The new motor is not set up with egr (egr block off plate). So today when I was installing the vacuum lines onto the new billet vacuum block I was wondering what to do with the line (hose) that was previously connected to the egr. Should I plug it at the vacuum block or does it get tee'd into another vacuum line??
Anyone have a vacuum line diagram for my set up??
BTW- I will be using a TT SD chip with the egr function disabled.
Thanks.
