Hi everyone from Pa
Discussion in 'Member Introduction's!' started by 93whitenotch, Mar 19, 2017.
  1. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
    20170304_143250_zpskprgo6qr.jpg 20170304_143329_zpsnii2bir9.jpg Just picked up my first Buick. 1987 T Type, I love the car always wanted one. This is my favorite color combo white blacked out trim.
    #1 93whitenotch, Mar 19, 2017
  2. NY Twin Turbo
    NY Twin Turbo
    Expand Collapse
    All the good stuff.....Times 2.
    Dec 10, 2014
    1,726
    344
    Offline
    Welcome. Tell us more.
    I especial like the supper clean minimalist look with the deleted bumper trim on the white bumpers. Fiberglass? I presume?
    Is the front bumper done the same way?
  3. seedling
    seedling
    Expand Collapse
    Jun 17, 2012
    367
    98
    Offline
    White on white just looks right!! Nice car, welcome aboard!
    • Agree Agree x 1
  4. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
    Yes glass front & rear bumpers & hood. lots of mods, stroked 4340 crank, k1 rods, wiseco pistons, Erson cam custom cam 228/218 @.050 504/504 lift, heads cleaned up , t&d rocker arms, ss headers, turbonetics t66 , 400 turbo trans with brake, 3000 stall, 3:73 gears, coil overs on rear, twin pumps in tank, Still finding more and more as I dig around on it. Last owner did not know a lot about car but motor he had done. Should be quick he never ran it at track.. Needs better engine management old Accel on it now..
  5. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
  6. SPOOLFOOL2
    SPOOLFOOL2
    Expand Collapse
    Fiberglass bumper filler dude. (949) 433-1257
    Staff Member
    Apr 4, 2002
    5,114
    992
    Offline
  7. Dennis Kirban
    Dennis Kirban
    Expand Collapse
    Mar 5, 2009
    2,995
    236
    Offline
    Kirban 2 cents worth
    Nice car some old school parts on it...example gauges over glove box....
    Your car appears to be a Turbo-T however door panels are from a Limited....
    You get a chance decode your trunk ID label....
    Not sure where in PA you are...but as it has been mentioned the biggest spring gathering is at my shop it is my 30th year over 4 grand donated on raffle items....rain or shine april 22nd plumsteadville, pa north of Phialdelphia.....
    Your name 93 notch back I assume you had a Mustang notchback popular fox body....we are the company that supplies all the mustang companies with the billet adjustablefuel regulator....for 20 plus years...known as billet or kirban it was the only one tested that fit under 16 different intakes on the fox body engines 5.0.....anderson motorsport in clinton Ill did it a few years back...
    your in fr a shock mustang versus turbo regal....parts are not as plentiful.....however value is greater.....
    denniskirban@yahoo.com
    • Like Like x 1
  8. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
    I have dash plate where gauges are and it says limited also...unfortunately the deck lid was replaced...so that label is not for this car...Will the vin tell if its a limited? 1G4GM1179HP4XXXXX The car has been repainted
  9. 626gn
    626gn
    Expand Collapse
    Feb 15, 2009
    2,050
    232
    Offline
    Welcome to the club. The fifth spot in your vin (M) identifies it as a Limited. However, Limited's came with a column shifter, different seats than what you have, plusher carpet... hmmm...
    #9 626gn, Mar 19, 2017
  10. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
    102_1212.JPG Funny you should say that... It did have column shifter... carpet has been replaced
    #10 93whitenotch, Mar 19, 2017
  11. Dennis Kirban
    Dennis Kirban
    Expand Collapse
    Mar 5, 2009
    2,995
    236
    Offline
    I figured the car is a mix of parts....based on seeing just the door panels.
    As you other photos show and has been pointed out it was a Limited column shift car....probably well optioned as the radio is the top of the line radio it was like a $504 option....
    Plus concert sound in the door panels.
    does the car still have the 2 VIN decals on the drivers door jamb area...?
    Prior to your purchase did you run a car fax?
    Get the car on a lift check VIN on engine block to see if it matches...
    Again I am not picking on your car just trying to help you access what you got.
    Is the carpet on the floor the plush high pile carpet as Limiteds had them....never mind I see car has black carpet so that has been changed.....
    got any engine photos?
  12. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
    No, I did not car fax.... The authenticity did not matter to me since its been so modified (repainted all jams)
  13. NY Twin Turbo
    NY Twin Turbo
    Expand Collapse
    Dec 10, 2014
    1,726
    344
    Offline
    Add to and /or modify this write-up and use this description of your upgrades in your signature file. This way when you write into the board for advise or to share info, others can view it before responding. It saves you a little trouble having to describe your combo every time you make a post.
    Sorry to here about the Accel engine management system. It worked for years for so many though.
  14. 626gn
    626gn
    Expand Collapse
    Feb 15, 2009
    2,050
    232
    Offline
    Ahhhh, makes sense now. Also, going from a column to floor shifter required a switch to bucket seats. If you did not already know that Limited dash plaque is special. Only on the Limited's did they light up. It's a very soft light though, you would not be able to see it during the day with your lights on. Good luck with the car. Should be a screamer once you get it sorted out.
  15. 93whitenotch
    93whitenotch
    Expand Collapse
    Mar 18, 2017
    9
    0
    Offline
    Checked vin on block...matches
  16. Buckshot G/N
    Buckshot G/N
    Expand Collapse
    Nov 2, 2011
    167
    18
    Offline
    Love them Old School Gauges, If you're in the York, PA area, you need put a hard effort in contacting Jim Dunne in Philadelphia.
    Jim knows the T/B thoroughly. And will have that white beast at peak performance.
  17. buddy
    buddy
    Expand Collapse
    Sep 6, 2013
    711
    115
    Offline
    IMG_1646.JPG Nice Buick we're almost twins.
  18. Joel A. Russo
    Joel A. Russo
    Expand Collapse
    Sep 7, 2013
    15
    4
    Offline
    Dale Cherry of Injection Connection in Horsham, PA is one of the best tuners in the area.
    Run that white beauty up to Harrisburg, there's a bunch of us with serious metal that get together frequently.
  19. TRICKSIXPA
    TRICKSIXPA
    Expand Collapse
    East Coast Go fast with class club MAGNA!!!
    Staff Member
    May 27, 2010
    1,619
    83
    Offline
    Welcome send an email to magnabuick@gmail.com and get on our clubs newsletter!
Share This Page
