TurboTnZ06
Go on red!
- May 7, 2002
Anyone install a Holley Pro dash yet? The 12.3 inch one. Says its 4.25 inches in viewable height and should fit behind a trimmed bezel hopefully. Can't decide if I want to get this or a new turbo?
I have the pro dash, not completely installed yet, looks like the Buick dash will need to be modified a lot to fit correctly. Maybe even moving the steering column down 1/2 inch. It’s lenght is great, height is a little big. This dash is not even comparable to a Dakota dash as all the functionality just blows all others away. Records, playback, can tune Holley efi thru touchscreen dash so no need for laptop. The wiring looks like a lot of work if you integrate turn signals, high beam, etc.
Nice!I have a guy who 3D prints bezels and brackets for the Holley dash. If someone wants to work with him to make one for a Buick let me know. You would have to be able to take some measurements and work with him on fitment.
Anderson performance has installed at least one and it is running on XFI.
Miy 87 GN is currently at Anderson's shop getting a pro dash installed and full Holley efi HP. Should be done soon.
Is Anderson’s install of the dash straight up and down, or does he tilt it so you look at screen more directly.
When your in the car you actually look down toward the dash, so I used a 5/8 spacer on the bottom and let the top lean back to get more of a direct look.
