Nascar83Fan
- Jul 2, 2010
The ecm will still have the error code stored and it'll show up as long as the error exists even if the service engine soon light isnt triggered by the ecm to turn on.
If the ecm loses power, such as the car battery being disconnected and then reconnected or the ecm orange wire fuseable link is unplugged and plugged back in would reset the ecm and clear any codes that were in memory. Unhooking the ecm from the car would also do the same thing, none of which should be done with car running or with the key on engine off position. Only under key off engine off position or key not in the ignition should one do any of the above to avoid possible damage to ecm and other eletronics in & on the car.
The scanmaster as long as the ecm hasn't lost power will be able to display what the last error code(s) are in the ecm's memory. The nal on scanmaster is where the mal codes would show up if any were being set by the ecm. The scanmaster itself doesn't store mal codes, it's only an interface to display what is being reported by the ecm and a couple other sensors are reporting to the ecm. It has no storing abilities, it's just a scan tool for diagnostic & monitoring functions for TR's and the TTA's. A modified version of the scanmaster was made for the syclone & typhoons that came later.
