R rorock23 New Member Joined May 1, 2009 Mar 26, 2011 #1 I need someone in Indianpolis,IN area who work on these cars!!!
phvrod FAST WITH CLASS Joined May 19, 2008 Mar 26, 2011 #2 phvrod Im in Plainfield..10 minutes away...What do You need?
R rorock23 New Member Joined May 1, 2009 Mar 27, 2011 #3 phvrod said: Im in Plainfield..10 minutes away...What do You need? Click to expand... need to get this thing running..
R rorock23 New Member Joined May 1, 2009 Mar 27, 2011 #5 no fire it cranks but no fire ...I will be working on the fuel system tomorrow..
Anarchy One fast Hot Air Joined Sep 9, 2010 Mar 28, 2011 #6 you should check the ignition mod. or the coil pack. that is whats wrong with mine. but im having trouble locating the ignition module on my car. i can see the coil pack right in front of me but i have no clue where the ignition module is located.
B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Mar 28, 2011 #7 The ignition module AKA coil module is attached to the bottom of the coil pak. It has the wiring harness plugged into it. Brad
Anarchy One fast Hot Air Joined Sep 9, 2010 Mar 28, 2011 #8 thanks man. now i feel like a a$$..lol. its right there in my face the whole time..lmao... wow daaaaaaaaaaaaaaaaaa!!!!!
Anarchy One fast Hot Air Joined Sep 9, 2010 Mar 28, 2011 #9 i have a 86/87 ecu. does that matter what ignition module i get. or can any just due fine. or does it have to be a 86/87 module.
B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Mar 28, 2011 #10 You need an 86/87 module. I have a good after marker used one which means it will not run an after marker tach. Let me know, Thanks-Brad
Anarchy One fast Hot Air Joined Sep 9, 2010 Mar 28, 2011 #11 and i would need a 86/87 coil pack as well. cuz im planing to swap both at the same time.
W WFO Habitual Line-Stepper Joined May 24, 2001 Mar 28, 2011 #12 Do a search for type II coils. Cheaper,way easier to find in junkyards. I've been running them for years. Type II Ignition Swap
