Today's surprise is that the injectors go static with a stock chip.
To actually get enough fuel on hand to run other then static, takes a big jump, in injector size, since your talking about having to drop to about 85% Duty Cycle to to get reliable injector operation. 50s *might* get you there, but 55s make it safe. Only down side is finding a chip guy that that can actually get them to work with your combo.
So you wind up with having to do signifigantly larger injectors, and then need to be able to fine tune things, so that means a ME or Translator Plus.
If you like doing headgaskets, then 36s can be made to go fast static until the headgasket lets go, or stay real mild in what you do timing wise.
