ETA on the chip , I hope you can make enough to not run out before all gets one .
within days. Should be no issue with supply.
B
Thankswithin days. Should be no issue with supply.
does this retain decel fuel cut off"
not at the moment, but it is something we may be adding if there is enough interest.
which brings up another point.
In the SD2 system, the majority of the air/fuel calculations are being done by the powerlogger itself, and the results are then passed thru to
the chip which then delivers the fuel. What this means is that features like DFCO could be developed and you would just download the new file into the PL.
Cool, huh.....
Bob
How fast do these fuel calculations happen? Relatively speaking
once every 16 ms, it could be done faster but it hasn't been necessary from what we have seen.
Bob
The closed loop rate varies with RPM due to lag time (transport lag) or how long it takes air to pump through the engine and hit the O2 sensor. It's slow at idle, fast at high RPM.
It is preset in the backround and not currently changeable by the user.
Closed loop can be disabled temporarily for use with a 2-step, by supplying 12v to unused pin D11 at the ECM.
It is also disabled in the 1psi to 12psi area where boost is typically moving too fast for closed loop to be of any use.
