I can't believe people are to lazy to do it right what a way to hack up a car ohhhh well ..its YOUR cars
I think somebody needs to cut thier dosage of Prozac in half.
so when are all these modified cars are actually goin to run some #s at the track ??
Hello - I am New to the Boards - Can someone tell me how to remove the yellow connector from the top of the fuel pump- I am getting ready to remove the pump from a 1991 firebird
Duz
Some questions I have also, what was used to cut the fuel lines? I wonder too if the area that was cut will begin to rust, did you put anything over the bare metal.
I would consider this mod if it didnt cause any rust, mine already has a walbro 340 in it so I'm not worried about the purist thing
Having changed my pump this past weekend, I can understand why people would want to cut up the trunk...but I still wouldn't! I'd rather spend another 4 hrs. dropping and reinstalling the tank. It's nothin' but a little time
Scott, I think you did a very professional job. Should have been made that way from the factory.
There are pros and cons either way. For me I'm planning a new engine soon so I can imagine I'll be upgrading the fuel pump. It's good to know I can do it in 30 minutes flat next time! I've seen some youtube vids... going in from the bottom looks like a major mess and hassle! But like Scott said, it all depends on the right tools. The main drawback I see with Scott's method is it's not easy to clean the tank out well (I'm talking power spray / drain) as the manual says to do when swapping a fuel pump. It goes as far as saying that junk build up in the tank is the leading cause of fuel pump failure...
I'm glad I came across this forum and have a compressor! pneumatic tools are king as far I as I can tell.
The main problems I came across when doing this mod are
- figuring out how to anchor threaded rivets (online resources not so good)
- cutting the sheet metal with air shears (obviously practice first)
- cutting the metal fuel lines (need I say more?)
The air shears I bought used for about $20. check out harbor freight. The rivet tool couldn't have been more than $15. also from HF. It came with a pack of the threaded anchors too!
He did a very professional job on this!!! If he would paint everything white, 99% of the people would not know it was not a factory job.
