We all know the problem. The pull straps get loose you take covers off tighten them and they get loose again.
GM put the pull straps directly into the door panels using sheet metal screws. After 27 years they look like this.
To fix this you need a threadsert kit. I got a decent marson kit from summit racing.
Using a step drill drill the hole out to the size recommended in the insert. Get this right because the insert has knurl's that need to grab the sheet metal.
Pop the insert in place and then tighten a bolt down in it.
All better now. You can actually pull on the pull straps.
