dr_frankenstein
Mad Scientist
- Mar 17, 2008
Okay so I have gotten many PMs asking how this is done and why there is such cost involved for making something shiney.... So I will show you guys how its done so anybody here can do it theselves!
Thanks to Turbo Joe - He was the first to take the plunge for a Buff job and since he provided his cover for us to all learn on, We thank Joe and his polish was on the house!
Todays approach is one of the average home mechanic, one that has the skills but maybe not so much the funds... So were go Budget Special.... Today were doing it with ALL HARBOR FREIGHT SUPPLIES AND EQUIPMENT!
PART 1.
Okay so Pic 1 shows most of the basic equipment you may need... as you polish you will find that some things work better then others and you will develop your own tools for corners or curves. polishing is very time consuming, and requires a patient person.... but the results can be worth it. So we have bits of old used sand paper, a Dremel with a small ball stone on the end, a B&D "Mouse" palm sander, a Harbor Freight Die Grinder with a Harbor Freight Buffs ( Mushroom, Spiral sown and Felt Bobs come as a kit), and several random bits I use for corners or flats. Paint Sticks, Hotel Keys, old Rubber Fuel Line, 3/8" extensions, etc..etc.. can all be used to help the process, this will be up to you to determine what works for you. Now the Dremel, is a tool to be easy with... it can move alot of material fast (fast for polishing) and make work harder then it needs to be with excessive gouges or scratches. So go slow with this tool and use gentle pressure - rub your stone on a piece of soap stone BEFORE you start to work your aluminum.... this will help prevent the aluminum from clogging up the stone and keeping the grinding clean rather then smearing alumium chips and making gouges.
Pics 2, 3, and 4 show what were starting with, the volute is fairly smooth! YAY! somebody has already done alot of the work getting all the hard edges and cutting alot of the sand cast finish off. Pic 2 shows the surface upclose, and it becomes visable the scratches, scars and pits from the casting of the cover, then the smoothing that was done before... Pic 3 shows the area inside the volute.... still very rough and AS CAST still... a hard hard area to clean up... this is where that hard manual labor comes in... dont think the Dremel will solve all these problems... it will make matters worse by removing too much to fast in the wrong areas... this is typically a hand worked area!
So we have our piece... we have our supplies... we have most of the equpiment.... LETS START!
Step 1 ... Time to wash your piece. we all here know how to wash a part. I shouldnt have to explain much more then that... Use lots of DAWN or simular grease cutting soap to remove as much OILS AND GREASE as possible... this goes for your hands too. I myself like to boil the part for a few minutes in hot water to help release the oils. Use clean lint free paper towels or an old cotten T-shirt or pair of CLEAN cho-nies to dry. Clean NON-OILED air is great too!
Now the item is clean.... Take some nice HEAVY DUCT TAPE and cover all non polished and critical areas. all areas INSIDE the cover are OFF LIMITS PERIOD... you dont want the sand paper, the wheel, the compound the dust, none of that junk in there... its asking for trouble down the line. this is an abrasive process and neither turbos or engines like the stuff from the polishing process.
TO THE NEXT PART!
PART 1.
TO THE NEXT PART!
