B00stJunkie
- Jan 6, 2014
Basically Im going to look at a 85 we2 gn with a 97 drive train tomorrow. Mod list is te-60 with Precision exhaust housing, 50# injectors with pte street chip, 3" maf 3200 stall, 2.5" down pipe, fuel regulator, double roller timing chain with sprockets, new aluminum radiator, under drive pulley (no percentages stated) arp cam bolts arp flex plate bolts, new oil pump gears and gaskets and a gn1 oil cooler with biggie oil filter adapter. The dude man is asking 6 but states at the end of ad, "needs head gaskets". My goals of this car is to have a street car that is not daily driven and a tinker toy I can work on. It will be a long term project I just want it to be drivable in between modifications. So with all that said, what would be an easy way to see if coolant has made its way to the oil without pulling the oil pan?
Could I just use the dip stick and smell/see color? Another member stated in my original thread that it's more common for just one gasket to blow, not both. The owner also stated that I cannot drive it and would have to tow it to my home, which makes sense to me cause if no coolant has met the oil, then there's no point in trying to drive it and then they find their way to each other. All input and opinions are welcome.
