Hp?
Sisaro
i was wondering if any body knew how much hp a stock 84/85 turbo housing with a 57mm compressor and a .82 A/R should be making?? and at what psi...... im just curious
200 hp @ 4000 rpm 300lbs of torque @2400rpm
12-14 lbs of boost this information was taken from chiltons general engine specifications hope it helps
those sound like stock numbers for the motor but the motor was 190 hp and 310 ft lbs.
I was talking about the added horsepower that should come from said above turbo configuration.
