I came on the forum 5 years ago, saying that, and I was shouted off. I guess it took awhile. For those who want to install junkyard brake products on their pride and joy, you certainly can do that. Brakes are, however, slightly more technical than cutting and cobbling. I see that many people spend LARGE cash to make their car faster, and then cheap out on the brakes. I never understood that. There was an all wheel drive Astro van that is way off base to adapt to the car, with it's angle bracket. Only the big van has a flat bracket. One has be to aware of the difference in the brake pedals between the Powermaster pedal and the vacuum brake pedal. Way off. A flat bracket requires the vacuum brake pedal. The pedal rod in the Hydroboost is crimped in, and we have a special puller to remove and reinstall the rod. We laser cut the proper mounting brackets, and have the proper pedal rods installed to fit. We use NEW BOSCH units, and also have aluminum master cylinders. The 2 SS or 4 SS hose sets have banjo ends precrimped for a clean look.
