tpabayflyer
- Jul 8, 2001
I was driving my 87GN easy on the highway and heard a ticking sound. It would change with rpm and I thought I had broke a rocker arm and itwasmaking the noise. I was not sure where the noise was coming from but it was not a deep rod knock at all. It sounded like valvetrain noise and the car felt like it was running on 5 cyl. oil pressure was normal and no oil leaks or any extenal damage. I stopped the car on the highway and gave it a quickcheckand figured I would drive it to the next exit and shut it down.I made it about another mile and it shut off byitself and did not restart. It cranks over normally and seems to have normal
compression. I had tocalla tow truck and had no time look at the car as I hadto rush out of town untilfriday. I willpull the valve covers as soon as I get home and checkit out.
Of course I had justspent the better part of 2 months doing some upgrades thatincluded
JC TE-44
HV timing cover
F-body rad
external oil cooler
new waterpump
new edelbrock timing set
scanmaster
I had about 80 miles on the car since doing the upgrades and everything was fine. I have 132Kmiles on the car and I am the originalowner. Is it possible the new oil pump was too much for the lifters and I had one collapse???Cold oil psi was 70 psi at startup with 10w-30oil and would settle to30-40 at a hot idle??
Is it possible the crank ignition got funky on me and broke??? I would have to assume that there is no spark as the car would not start. If anybody can shed some light on this I would really appreciate it . Thanks in advance. TBF
JC TE-44
HV timing cover
F-body rad
external oil cooler
new waterpump
scanmaster
