Hi,
Minimum authority (that's what Buick calls it) idle adjustment is pretty critical, so you need to set that before proceeding. They have a cap on the screw for a reason. It sounds to me like your IAC is out to lunch.Also, verify TPS setting after your readjustment of base idle.Good luck with your troubles...
