ignition on wire.
chumanga
im hooking up my preluber and im not to handy with electrical stuff... i need to hook up a wire that needs to be connected to a wire that has juice when the key is turned to the on position but doesnt cut out when trying to start the motor so i guess a wire that has power always when the car isnt turned off... in the engine compartment would be best.
thanks a ton
Lance
I also have a preluber. Hook the trigger wire into the fuse box labeled IGN. I don't remember if they're all functional but I know one or two are.
I know you want a wire in the engine bay but it's nice to run it inside the car to a switch to disable it. It gets pretty annoying when you're working on the car and have to turn the ignition on and off. After I ran the battery down, I installed the switch inline with the trigger wire.
