<- what he saidTurboSlacker said:Get hold of Gene and take it to Speedway Automotive in Lynnwood. Gene will help ya out.
JP87GN said:I give up! I'm throwing in the towel!
I guess that was the problem and im glad you found it I believe that was one of the things i told you to checkJP87GN said:The harmonic balancer pulley bolt was hand tight and at certian rpm's it would vibrate and hit the crank sensor and knock the spark out of the motor..
Yes, I think it was the first thing out of your mouth after I told you what was going on! Props to Geno for the diagnosis! I'm glad its fixed. I was ready to throw the car cover on it and send it into early hibernation!geno said:I guess that was the problem and im glad you found it I believe that was one of the things i told you to check
JP87GN said:I've had a change of heart and will know have to punish Dan at TT6! Yes ,Victory is mine!
