tpabayflyer
- Jul 8, 2001
I hear the cometics are really nice but I don't know if I really need them. I have a stock 135K mile engine and there is a bunch of carbon behind the intake valves so I will pull the heads today.
I plan on using the stock valves with bowl porting by me and a good 3 angle valve job with the intakes backcut. I am not a big racer but I plan on getting into the high 11sec range with a TE-44 boosting around 23psi on alky. I have a few questions....
What fel-pro gasket do I use or get the cometic????
Use new larger valves?? what size (must use stock seat)
What arp head bolts do I use? (can't re-use stockers I guess)
I need to get a new set of lifters.. what brand??
( I had a lifter collapse... stock cam/valvetrain)
I recently made some upgrades that included the HV timing cover and I'm thinking the 70 psi oil pressure was a little much for the 18 year old stock lifters?? Any advice on removeing/replaceing the heads would be aprreciated. TIA TBF
