Indentify this turbo please
smokingunz
I just would like a confirmation of what it is, I pretty positive its a TE44 but not what housing? Thanks
I dont see any markings as far as housing, it just says precision? Do I just need to measure, and if so where exactly ?
I see 4431 on the label
Ok...going to show my ignorance...what exactly is a 4431, I searched it but its to sift through many long threads? What exactly do I have and whats the difference between it and other TE44 stlye turbos?
Precision Turbo Entry Level Turbocharger - 4431E PTB003-4431 PTB003-4431
HP Rating: 565
Are you trying to put together a cost effective turbocharger system for your vehicle? Well, we've got just what you're looking for! Precision Turbo and Engine's line of Entry Level Turbochargers provide the perfect solution by delivering a high-quality turbo at a budget-friendly price.
This Entry Level unit features the following:
�?� 58mm inducer compressor wheel
�?� "E" compressor cover 3.0" inlet/2.0" outlet
�?� T31, 76 trim turbine wheel
�?� Turbine housing options:
- Buick .63 A/R
- T3 .48 or .63 A/R with 4 bolt discharge
- T3 .48 or .63 A/R with 5 bolt discharge (with or without wastegate hole)
�?� 360?� journal bearing system
HP Rating: 565
- Buick .63 A/R
Thanks Jas, thats a lot of good info...that being said, how does this differ from the common TE44?
