injector harness for low Z injectors and XFI
asloan5
Corn Fed alcoholic
I just purchased the xfi with casper's adapter and 160lb injectors. I'm starting to install my original injector harness and noticed 1 slightly broken injector plug. I looked at racetronix and capsers replacement injector harness. Which one should I go with I see some options for a hotwire injector harness is this what I should use ? see links below
G77-INJ-AB
CEI - Casper's Electronics, Inc.
I bought the injector hot wire kit from Racetronix. Top notch quality. However Caspers is in the US and they make goood products too. I would get the injector harness with the Hotwire option. I noticed an immediate difference on my car(Gen 1 BS3 and 95s) I had to trim the fuel down in idle and cruise. I leaned the idle table out 1/2 AFR point and it runs great. Still working on the car so WOT passes to report on though. hope this helps. Jeremy
