I have been trying to sort out a rich condition and a popping through the exhaust at low rpm for some time. The pop was there before the rebuild and after. Everything was changed except the maf and the injectors. I started pulling plugs to check and see what they looked like. Number 6 was burning rich and it was a little bit moist. I put the coil tester on it and my coil is perfect. The only thing left is the injectors. They were on there when i bought the car so that makes them maybe 5 years old, they are 42.5 injectors. I was going to pull them and have them cleaned and flowed. Will the cleaned and flowed injectors perform well or would it just be better to skip the 85 dollar charge and just buy a whole new set of 50s??
Dan
Dan
