buickpower
polytetrafluoroethylene
- Jun 27, 2003
i know i will have to get an 87 ecm and custom chip burned, but i just wanted to check with you guys to see if my figuring sounds feasible. I figured out i would need 37# injectors to feed my engine the fuel it should need, i was just wondering if it would be wise to go with 40lb or 42.5 if i should crank the boost. Or is this simply too much injector?
