Ok, I know how to route the hoses that is the easy part. Figuring out how to mount this sucker is my problem. The 4 plastic fastener type things with plastic nuts and foam adhesive pads come with the kit and I consider them useless. You need to pilot the plastic fasteners throw your ac consdenser and radiator. Not going to happen. I just put an aftermarket power steering cooler on my s10 and I was not thrilled with how I had to install it and I said to myself, no way am I installing the transcooler this way. So there is some other hardware in the kit, 4 flat metal pieces with holes and various bolts and screws. I do not have a front mount. Has anyone else installed with the "other" hardware and not use the plastic and foam? Any tips would be appreciated.
