I have gotten three different stroies on how to install this Art Carr Non Lock-Up Valve and I am not sure what to do. Here is my situation:
I have the trans in the car, the engine is out of the car. I do not have a puller for the front pump. I have a new Art Carr 16930 converter.
Do I need to remove the trans to install this kit?
Art Carr tells me I do not need to remove the front pump or install the 5/16" plug after tapping the pump. Is this true?
Can I change the valve by dropping the pan and the lock-up solenoid (this is what Art Carr said I should do)?
I would really like to get this done the correct way the first time. The answers I have received have ranged from having to pull the trans out and stand it on it end while removing the pump to not even having to worry about putting the non lonk-up valve in at all.
Could someone please help me with this. I would prefer to just leave the trans in the car, change out the valve and install my new engine. Any advise will be greatly appreciated.
Thanks,
Mike![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks,
Mike
